USING SAND LADDERS!
Sticky USING SAND LADDERS!
Post by Rislar on Sat Jan 16, 2010 9:50 am
USING SAND LADDERS
An experienced driver will call for a sand ladder before too much digging is required. If the vehicle has been allowed to dig itself in to the extent that the vehicle’s weight is resting on the axles or chassis, a great deal of digging and jacking will be required. Do not dig a little and then attempt to drive out. This is a waste of time – if the attempt is unsuccessful the entire digging effort will have been wasted because the spinning wheels will replace the sand you have removed. Dig until you are sure that more digging would be a waste of time.
Dig channels in front of the wheels that appear to have the least traction and lie the ladders in front of them. If in doubt as to the wheels under which to lay the ladders, select the front wheels, since once the vehicle gets moving the rear wheels will also get the benefit of the extra traction (assuming you are driving out forward).
If in sand with the rear wheels sunken and the front wheels remaining clear, place the ladders under the rear wheels. Dig out a channel in front of the other wheels too, so they do not have to roll over any ridges of sand that may have built up in front of them. In very deep sand the sand ladders may get buried when the vehicle drives over them, so mark the position of the ladders with a spade.
Unfortunately for those doing the pushing, this may mean a bit of a walk, as it is important for the vehicle to be driven to firmer ground before it is stopped. The sand ladders will have to be dug up and carried. Attaching a rope to tow them out is not wise as the extra drag can cause the vehicle to bog down again.
Sticky Re: USING SAND LADDERS!
Post by Hicube on Sat Jan 16, 2010 11:28 am
Yet another great guide for the 4x4 off roader Clap Clap
