Volkswagen Amarok Pick-up (2010 - )
Sticky Volkswagen Amarok Pick-up (2010 - )
Post by Rislar on Mon Jan 18, 2010 9:24 am
Originally shown as a concept kitted out for Search and Rescue at IAA in Hanover w/c 23-9-2008. 5,180mm long and is 1,900mm wide. In production from end of 2009 at Volkswagen’s ‘Pacheco’ plant near Buenos Aires in Argentina and introduced initially to markets in Europe, South America, South Africa and Australia. Initially only available with four doors and four seats with room for standard-sized Euro pallet sideways in the flat cargo bed.
Pickup shown at the IAA has been designed for use as a ‘Search and Rescue’ (SAR) vehicle by lifeguards and was conceptualised following consultation with emergency services as well as in-house emergency vehicle specialists. As a result it features, among a host of other features, GPS, a multifunction touchscreen infotainment unit, CB radios, a number of chassis and all-wheel drive functions, a compass, flashlights, a defibrillator and binoculars. Life jackets, rescue buoys, fire extinguishers, blankets and a tool kit are also all incorporated.
The name Amarok means wolf in the language of the Inuit, one of the Eskimo people who live in northern Canada and Greenland who highly regard the wolf as king of the wilderness and a figure of robustness, endurance and superiority. It translates into "he loves stones" in the languages spoken in South America.
Developed from scratch, the Amarok will be launched as a double-cab pickup with four-wheel drive, while a single-cab version will be introduced later. It will be powered by Volkswagen's powerful yet efficient, next generation common rail turbo diesel engines which will achieve class leading fuel consumption and emissions.
First production version photos 1-12-2009.
Payload capacity of up to 1.15 tonnes
Maximum towing limit of 2.8 tonnes
2.52 m² load area has largest dimensions in its class
Load area 1,555 mm long,1,620 mm wide
1,222 mm between wheelarches to take Euro pallet
Rear-wheel drive, and switchable or permanent all-wheel drive
Double cab available from launch. Single cab to follow in 2011
Production from December 2009 at VW factory in Buenos Aires, Argentina ahead of its worldwide launch starting in its native South America in early 2010 and in Europe next summer, with first models expected to be in UK Volkswagen Van Centres in September 2010.
The Amarok has a generous payload capacity of up to 1.15 tonnes and maximum towing limit of 2.8 tonnes. Its 2.52 m² cargo area has the largest dimensions in its class at 1,555 mm long and 1,620 mm wide, plus a best in class width between the wheelarches of 1,222 mm, which means that for the first time on a mid-size pick-up, it is possible to load Euro pallets sideways, saving on space.
The official photos show the Amarok reflects the latest Volkswagen design DNA with frontal styling in line with the latest Transporter and Golf. It is 5.25m long with a ladder frame chassis and will be offered with a choice of rear-wheel drive and switchable or permanent 4MOTION all-wheel drive.
For maximum convenience, the switchable all-wheel drive is engaged by the push of a button, and also has low range off-road gearing.
Full-time all-wheel drive version is a rare on pick-ups, and uses a Torsen differential to distribute drive at a 40:60 ratio to the front and rear axles for excellent vehicle dynamics and high traction, and also ensures that the wheel with the best traction always gets the most power. A rear differential lock is available.
Designed to tackle the toughest off-road terrain, the Amarok is offered with an electronic differential lock (EDL) and Off-Road ABS to significantly shorten braking distances in off-road conditions or gravel roads. At speeds of under 20 mph it also activates Hill Descent Assist to control hill descents by using selective braking interventions. Furthermore, the ESP Plus system includes Hill Hold Assist, which prevents the vehicle from rolling back by holding it in place on inclines until the driver presses the accelerator pedal.
Under the bonnet a choice of two 2.0-litre fuel-efficient, Euro5 compliant, common rail TDI engines producing 163 PS, with torque of 400 Nm at a low 1,500 rpm, or 122 PS with maximum torque of 340 Nm from 2,000 rpm.
Both engines have a six-speed manual transmission and will have impressive fuel economy with low emissions to make the Amarok the first all-wheel drive pick-up in this class offering CO2 emissions of less than 200 g/km. Like the new Transporter and Caravelle, the Amarok has a gearchange indicator to help drivers achieve the best fuel economy, which with an 80-litre fuel tank should offer a range of over 600 miles.
UK prices and specifications will be confirmed nearer the Amarok’s UK launch. The range is expected to comprise a standard model for customers who need a pick-up that is as robust and practical as possible, to offering all the latest luxury items expected for those using Amarok as a leisure vehicle. An extensive accessories programme will also be offered for the Amarok – from a styling bar and running boards, through a cargo cover and Multi-Connect load securing system to a selection of stylish alloy wheels.
