Mitubishi L200 Introduction!
Post by Rislar on Mon Dec 28, 2009 1:20 am
Introduction
DELIVERS THE GOODS
For many years the Mitsubishi L200 has led the world of one-ton pick-ups - its inimitable style, excellent performance, exceptional build quality and superb level of specification leading the authoritative What Van? to vote it Best Pick-up eight times in the last eleven years. It is, they say 'a joy to drive', they 'love it to pieces'.
And now you can find an L200 with single cab, double cab and club cab bodies. All are powered by the same powerful 2.5 litre turbocharged and intercooled engine; all benefit from the same wide-track stance with sophisticated double wishbone front suspension and rigid leaf-spring system at the rear; all enjoy the same responsive power steering, light clutch and sturdy five-speed transmission. So many good things, so much choice.
With its four doors, five seats and generous loadbed the L200 Double Cab is a true blend of car and carrier. Simply streets ahead of the pack it delivers massive peak torque of 177 lbs. ft. at just 2000 rpm and will pull a mighty 2700 kg. And, since it also enjoys the benefits of part-time four-wheel drive, you can shift the transfer lever and venture off-road for some real entertainment. With four stunning editions on offer you can find a Double Cab tofit your needs precisely. If you need to do more work than play, you'll find that the 4Work strikes the perfect balance between comfort, good looks and supreme practicality. But if you demand something with rather more street-cred you're completely spoilt for choice. Should you go for the sophisticated 4Life, the mean 'n' moody Warrior or the ultimate in hot wheels, the ever-cool Animal®️?
