version LE auto
version LE auto
Post by mad max on Wed May 05, 2010 2:31 am
hi Hicube what say you the mechasnical specs of my choice of vehicle LE Auto
4WD
Automatic
(LE)
4WD
Manual
(SE)
4WD
Manual
(Standard)
2WD
Automatic
(Calibre)
YD25DDTi
ENGINE
Type
4-cylinder, In-line, DOHC
16-valve Turbo Charger with Variable Nozzle Turbine(VNT) with
Intercooler
Intercooler
Intercooler
Intercooler
Displacement (cc)
2488 2488 2488 2488
Bore x Stroke (mm)
89 x 100 89 x 100 89 x 100 89 x 100
Max. Power (kW (ps)/rpm)
128 (174) / 4000 128 (174) / 4000 128 (174) / 4000 106 (144) / 4000
Max. Torque (Nm (kg-m)/rpm)
403 (41.1) / 2000 403 (41.1) / 2000 403 (41.1) / 2000 356 (36.3) /2000
Compression Ratio
16.5:1 16.5:1 16.5:1 16.5:1
Fuel System
Common Rail Direct
Injection controlled by ECCS 32 bit
Common Rail Direct
Common Rail Direct
Common Rail Direct
Fuel Type
Diesel Diesel Diesel Diesel
Fuel Tank Capacity (L)
80 80 80 80
TRANSMISSION
Type
5 AT (5-speed automatic) 6 MT (6-speed manual) 6 MT (6-speed manual) 5 AT (5-speed automatic)
Gear Ratios 1st
3.827 4.692 4.692 3.827
Gear Ratios 2nd
2.368 2.705 2.705 2.368
Gear Ratios 3rd
1.520 1.747 1.747 1.520
Gear Ratios 4th
1.000 1.291 1.291 1.000
Gear Ratios 5th
0.834 1.000 1.000 0.834
Gear Ratios 6th
- 0.827 0.827 -
Gear Ratios Reverse
2.613 4.260 4.260 2.613
Final Gear Ratio (hypoid final gear)
3.538 3.692 3.692 3.357
Drive System
Electronically Controlled
4WD system; 2H, 4H & 4L
Rear Wheel Drive
SUSPENSION / CHASSIS
Suspension - Front
Independent Double
Wishbone with Coil Over Shock Absorber and Front Stabiliser bar
Independent Double
Independent Double
Independent Double
Suspension - Rear
Multi Leaf Spring with
Shock Absorber
Shock Absorber
Shock Absorber
Shock Absorber
Steering System
Power Assisted Rack &
Pinion Steering
Pinion Steering
Pinion Steering
Pinion Steering
Min. Turning Radius (curb to curb) (m)
6.5 6.5 6.5 6.5
Brake System
Dual circuits; front
& rear distribution with ABS & EBD
& rear distribution
Brake - Front
Ventilated Disc
Ventilated Disc Ventilated Disc Ventilated Disc
Brake - Rear
Drum Brake with
Load-Sensing Proportioning Valve (LSPV)
Drum Brake with
Drum Brake with
Drum Brake with
Brake - Parking
Centre-lever Type
Centre-lever Type Centre-lever Type Centre-lever Type
Alloy Wheel Size
16"x 7J 16"x 7J 16"x 7J 16"x 7J
Tyre Size
255/70R16 255/70R16 255/70R16 255/70R16
Approach Angle
32˚ 32˚ 32˚ 32˚
mad max
Re: version LE auto
Post by Hicube on Wed May 05, 2010 10:52 am
Hi Max,
Good choice, I have the same type Auto as that Cool
It drives really nice with loads of power on tap. The Auto's are known to be a great drive, but they do use a little more fuel than the manual versions.
With the sort of milage you are going to do, i would stick with an Auto tho..... Far less effort than changing all those gears grin
Re: version LE auto
Post by mad max on Wed May 05, 2010 6:21 pm
Thanks hicube i knew you would have said i have made a good choice you the man for me now thanks for the feedback black it is and the version LE auto is the final choice after going through the details and feedback from kind souls out there
I've made up my mind shall get in touch with you soon as I have made the finishing to the vehicles and and all other additions to the vehicle and I shall put my ride for all to see
mad max
Re: version LE auto
